troubleshoot blinking green light
Mitsubishi WS-55859 blinking light occurred after storm. light blinks continuous
Esta é uma boa pergunta?
frank de los reyes, for blinking light symptom you should try replacing the capacitors on DM first. Download some instructions from here. The link will directly download a PDF file describing how to replace the caps. Also, check this guide Different model same issues same layout. This model series was plagued by a bad DM module that caused multiple failures on all other boards. there were also issue with the EEPROM Board failure after power outages.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 79
