My vizio tv comes on but no disply
my vizio m3d460srp 3d tv comes on but but no display i can see the menu but very faint i also can see the glow through the back of the tv in a dark room
Esta é uma boa pergunta?
larry, "see the menu but very faint i also can see the glow" means your backlight is out. This could be a PSU issue for simply not supplying enough power to your backlight. The next possibility could be the LED driver board itself. I'd check for any bad/broken caps and bad solder joints. If not results with that I'd replace the board. Part number for that is 715G4863-P01-000-004S Post some images of all your boards with your question. Maybe we can see something a bit more obvious. Use this guide to post images with your question.
Esta resposta foi útil?
it s turn on no signal and turn of
Joseph Renfort not sure if this is a question or an answer. What model is this and what exactly does it do? Sometimes a well formulated question can actually help to fix things.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,403
