Ir para o conteúdo principal
Repair guides and support for smartphones in the Curve line produced by BlackBerry since 2007.
69 Perguntas Visualizar todos
My BlackBerry Curve 9320 phone is not getting started...
my phone is not geeting started after software upgrdation ...
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
I had the same issue and fixed it with a hairdryer! Try taking out the battery, blow drying it for a little while on all sides. Then blow dry the keys of the phone and inside where the battery goes. I don't know why it worked but it did. I assume there was either dust blocking connections, or some moisture causing issues.
Esta resposta foi útil?
Pontuação 0
hello Hari Saladi ,
it is very easy to fix your phone. case is the firmware not update properly
Use this line to download JL commander
  • install jl commander
  • connect your blackberry to pc via USB cable
  • select option 5 (reset to factory defaults)
  • your phone will be restart and hangs with error on white screen
  • install blackberry desktop manager using this link
  • update software gain
after updating the software you can use your blackberry with better performance ever !
Pontuação 0
Adicionar a sua resposta
Hari Saladi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 410
