Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
iPhone 5c reboots itself after 3 minutes and battery % doesn't change
I have just upgraded my iPhone 5c to iOS 8.4 and my phone started acting wired its rebooting itself after 3-5 min when ever I am charging my phone and my battery usage is not being displayed properly it shows 100% all the time even after using it for 4-5 hrs. Recently I have also notice that when ever i shake my phone there is a strange sound coming out of my phone like something is dislodged in my phone. Could this be a problem with battery or something else or do I have to replace my old battery.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
This could be an issue with the battery, the gas gauge of the battery may be damaged, and that's why you are getting improper readings.
The battery itself could be damaged also, try replacing the battery and it should be ok. :-)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
kns prasad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 109
