First generation of Citroen's supermini car.
29 Questions View all
refill of C3 Aircondition system
How much R134a oil contains the aircondition system on an 2003 Citroen C3 1,4 HDI 16 Valve (92 hp) ?
Score -1
Add a comment
1 Answer
Chosen Solution
This is the best info I could find. If you need to know the exact amount of oil there should be check your local library for a Chiltons manual for reference. I hope this is of some use to you. Ralph
http://reviews.ebay.co.uk/Citroen-C3-Air...
Score 5
2 Comments:
+ nice
by
Hi Ralph ,Thank you very much for your answer, after checking at my local library , I found out that the right amount of R134a was between 0,575kg and 0,625kg , the amount in the system was 0,320kg , and the air temperature in air-outlet was about 11 degrees celsius, after refilling to 0,600kg , it was about 4 to 5 degrees celsius , so quite a difference. Best regards Finn
by
Add a comment
Add your answer
Finn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,791
