Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Perguntas Visualizar todos
Why won't my transmission go into drive
2005 Nissan Altima Transmission won't go too drive just 1,2, n 3rd. When you put shifter into drive it shows up as 3rd on dash instead of D. Runs and shifts through first 3 gears fine just won't even try too go into Drive
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
If you have the regular automatic the slot where D is has more to it. If the gear position characters say 3 D with 2 and 1 below the 3, the left side of the slot is for 3rd, while the right side of the same slot is actually D. It's quite easy to drop it into 3 straight from Park and/or Reverse, especially if you're in a hurry. Just push the shift lever directly towards the passenger door, you'll feel it grab another gear, assuming everything else is good. I hope this is all the problem is, and if it is don't feel bad. My wife drove our 02 in 3rd for the first two months we had it! :-)
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have tried everything and still have this problem
por
Adicionar a sua resposta
Jeremy Farthing será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 4,566
