Ir para o conteúdo principal
How long should a new battery be charged before using?
Hi!
I just got a new battery from ifixit and i wanted to know how long should i charge the new battery the first time.
Esta é uma boa pergunta?
Pontuação 4
2 comentários
I just got my phone battery replaced as my previous battery had bulged out, my new batter seems to take a long time to charge, is it normal for a new battery to take longer to charge as it's new?
PS: THIS IS THE FIRST TIME I'VE PUT THE PHONE TO CHARGE AFTER REPLACING THE BATTERY AND ITS TAKING A LONG TIME.
por
i just changed my 6s battery and the service guy told me to charge it 12h straighy without using then its alr
por
Adicionar um comentário
6 respostas
Solução escolhida
Charge till 100% full, however long it takes. Let it trickle after that for say 30 minutes (means leave it connected to charger after it reaches 100%).
From there use it in one go without charging until almost 0%.
Then charge it in one go without interruption till 100% full. You can let it trickle a little bit.
The above is called calibration.
If you decide to leave your phone turned off and unused for a long period of time, do it when the battery is at 50% capacity.
Always use a genuine wall charger, and a genuine or certified cable.
Heat will damage your battery.
Extreme cold will diminish its capacity temporarily, until the temperature rises again.
Esta resposta foi útil?
Pontuação 8
So there are conflicting instructions on iFixit when you follow the instructions such as the ones from iFixit Battery Calibration
How to calibrate your battery
For phones and tablets:
1:Charge it to 100% and keep charging it for at least 2 more hours.
2:Use your device until it shuts off due to low battery.
3:Charge it uninterrupted to 100%.
When you receive the kit you get a card it says battery calibration with the I'll fix it logo on it it says (For Optimal Performance, calibrate your newly installed battery. Drain battery below 10% then charge uninterrupted to 100%.) And that is all
So it's a little conflicting I'm going with the one from the wiki.
The funny thing for me is it's been at 1% for 5 hours this is a Samsung S7 Edge does anybody know if this is normal? However, it did say the battery was too low to use flash when I took that picture maybe it's getting closer to shutting off.
I just want to say iFixit is really cool I couldn't believe what I paid for my kit $32 came with everything to replace the battery. The instructions were straightforward and clear to understand to tear it apart however, they should have an up-to-date adhesive strip tutorial because that got a little confusing for me even with doing some Googling but I did manage to figure it out. Perhaps on your tutorials iFixit after congratulations you've installed your battery now let's put the phone back together in this second tutorial just a thought. :-)
Pontuação 0
1 comentário:
I broke my screen and digitizer on a iphone 6 plus and the battery was going dead.
I bought a new screen & digitizer and battery on ebay for $45 and DIY. Looks and works GREAT!
por
How if I doesn’t wait till 0% I already charge, is will damage the battery?
Pontuação 0
“There’s a reason Apple no longer recommends calibrating the battery in your iPhone, iPad, or iPod. It’s bad for battery health. They’re even introducing a new feature to keep your battery from charging to 100% when you don’t need it to.”
https://appletoolbox.com/why-you-shouldn...
Pontuação 0
I have a IPHONE 8 Plus and I purchased a new battery a couple of days ago and it seems to still take a long time to charge?
Pontuação 0
i had a new battery put on my iPhone 6S plus and its taking long to charge. Its not switching on either to show signs of life. Is it normal
Pontuação 0
Adicionar a sua resposta
tawisti será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 36
Últimos 7 dias: 218
Últimos 30 dias: 769
Duração total: 81,391
