Pular para o conteúdo principal
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
235 Perguntas Ver todas
White screen after replacing screen
I ordered a replacement screen+digitizer after i dropped my phone.
When I replaced the screen and turned it on the screen goes completely white.
The phone seems to function as it still makes the boot sound and input sounds.
However when I try to turn it off it just turns itself back on.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
kits de reparo de baterias de iPhone
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Solução
Solução escolhida
Hi Rowen,
It is possible that you have received a faulty item, you could try and get a new one from the same supplier if it is faulty. You could also try resetting the phone but I believe this is a hardware issue and not a software issue. :-)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rowen Lente será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Todo: 381
