Ir para o conteúdo principal
Model M7572 / 400 or 500 MHz G3 processor
512 RAM installed on bottom of processor card; computer won't start
I followed the install directions carefully to replace 256 RAM with 512 RAM. Installed it on the bottom of the processor card but now the computer won't power up.
Is something not seated properly?
Esta é uma boa pergunta?
Pontuação -1
5 comentários
probably
por
I decided to go back and put the 256RAM back on the bottom. I put the 512 on the top.
This time when I attempted to boot, I got the normal tone and things sounded right but the screen is black. Not home free yet.
por
Real easy to not seat the cpu board fully.
por
rj713 - your comment was right on. I went back and attempted to reseat the cpu board fully. Powerbook G3 booted normally and I can see 768RAM now. THANKS!
On to the hard drive replacement!
por
You should mark this post as solved somehow.
por
Adicionar um comentário
1 resposta
Solução escolhida
Reseat the cpu board. Ralph
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
eodted será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 1,333
