My bb playbook is not charging, what can I do?.
I have changed the charger and still will not charge. Even when I connected it to the computer it will not respond.
Esta é uma boa pergunta?
Did you inspect the charging port to see there is nothing stuck inside and it is free of liquid damage? Is all the connector pins silver and free of corrosion? When you plug it in, does the usb wiggle back and forth and left and right?
Esta resposta foi útil?
Thanks my brother, you are right the charge pot is completely clean as the brass strips are all missing. This simply means that the port will have to be replaced.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,071
