Ir para o conteúdo principal
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Why I can't charge my phone
My charger piece in the inside of the phone where i charge my phone is damaged how can i fix it
Esta é uma boa pergunta?
Pontuação 5
1 comentário
i want where to take phone it to fix the charge pots
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Hellow Caleb Ragsdale,
you can simply change the [http://daughter card |Why I can't charge my phone]
here is the teardown guide
if you have sound soldering skills you can change the charging port and it will cost around $2
Esta resposta foi útil?
Pontuação 3
Where do I find that for my phone can charge and how do I find it
Pontuação 2
how do i fix the charger port on on my phone it is broken
Pontuação 0
I had my prongs bent in by someone so I want to connect positive and negative inside to my charger wires BUT it has 2 red 2 black and 2 white, what to do? :( its a alcatel one touch fierce xl :( . + and - not labeled.
Pontuação 0
Adicionar a sua resposta
Caleb Ragsdale será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 1,157
