Ir para o conteúdo principal
HDMI Ports Suddenly Not Working
Verizon Fios Cable box signal still works fine on TV. The trouble is with the HDMI ports. We have an Apple TV, Sony BluRay, and LG DVD/surround sound unit each plugged in to the HDMI ports. None of them work, except for the Apple TV, but that signal shows with "snow" running over it. For the others, a "no signal" message appears on the screen when you select their input. I should note that each of these devices has been plugged into these ports for two-four years without trouble.
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
A common problem w LG:s HDMI switching IC.
Follow the circuit lines from HDMI ports and heat that IC with a heatgun. First time it worked for three months, second time only one week…
Have to replace that IC or main board some day.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jessica Olson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,181
