Ir para o conteúdo principal
The Sega Genesis (also known as the Mega Drive) is Sega's most successful video game console to this date.
37 Perguntas Visualizar todos
Why can't any controller plugged in as the first controller press up?
So I can use up on all my controllers in the 2nd controller slot so I know the controllers are fine. But whatever controller is in the first slot doesn't allow me to press up. I'm guessing there's something wrong with the connectors so I'm just wondering if I should just replace the whole thing or if there's an individual pin I could fix.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
I am not an expert on controller ports but if it is not letting you do certain tasks with your controller, it could be dirty. Try cleaning it with Alcohol and Q-tips/ paper towels. I would also recommend using a nylon brush (a toothbrush can work in a pinch if it is clean). Finally, when you finish scrubbing it down, use compressed air to blow any remaining debris out.
If cleaning it this way doesn’t work, then a deeper cleaning involving more tools such as picks from the cleaning section on ifixit may help. You can use those to force whatever is in there, out. But do this as a second last resort.
Worst case scenario, you’ll have to order a replacement part and sell the broken one online for parts. That way you can still decrease ewaste while fixing the issue.
Hope this helps!
  • Jakes Restorations
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Josh Lowe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 183
