Ir para o conteúdo principal
The X-Street Lamborghini Murcielago LP670-4 SV is a 1:10 scale fast RC Car capable of scaled speeds up to 100 MPH. Repair for this device requires common screwdrivers and prying tools.
5 Perguntas Visualizar todos
Why is the car turning by itself?
I am attempting to drive straight but the car keeps veering to one side.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The alignment dial is most likely out of balance. To fix this issue, locate the alignment dial between the front wheels on the underside of the car. If the dial is not straight, or in line with the car, then adjust the dial accordingly. For example, if the car direction goes left, then adjust the dial to the right side.
For more information, please refer to the troubleshooting page found at X-street Lamborghini Murcielago LP670-4 SV Troubleshooting
Esta resposta foi útil?
Pontuação 0
1 comentário:
However after doing this after turning it goes out of line again
por
Adicionar a sua resposta
Liam Martinez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 333
