Ir para o conteúdo principal
The X-Street Lamborghini Murcielago LP670-4 SV is a 1:10 scale fast RC Car capable of scaled speeds up to 100 MPH. Repair for this device requires common screwdrivers and prying tools.
Why won’t the remote turn on?
I am switching the remote control to the on position but the light is not illuminated.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I lost my remote for this model car. How can I get a replacement remote?
por
Adicionar um comentário
1 resposta
Solução escolhida
The remote control most likely has a dead battery. To replace the battery, slide open the lid at the bottom of the remote control and take out the 9V battery. If you have a voltage meter, test the battery to ensure it is dead. If the tester reads less than 7.5 V, it won’t be able to power the remote. Obtain another 9V battery and follow the voltage testing procedure to make sure it has enough charge to power the controller. If it is fully charged, insert the new 9V battery into the remote control. Note that the positive and negative terminals must be aligned properly.
For more information, please refer to the troubleshooting page found at X-street Lamborghini Murcielago LP670-4 SV Troubleshooting
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Liam Martinez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 7
Ao todo: 240
