Ir para o conteúdo principal
The Dell Dimension 2400 is a desktop computer released in 2003 with a traditional box "tower" form factor and a black exterior. It is the last machine from the Dimension 2xxx series and is equipped with a Celeron or Pentium 4 processor.
8 Perguntas Visualizar todos
What parts do I need for my dell dimension to boot up
Computer doesn't boot and this is the screen in setup. I know i need something so does it matter the brand or model?
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
1 Resposta
Solução escolhida
fault is your Hard disk is not detecting by the bios.
1) Check the IDE cable
2) Clean the IDE connectors
3) Check the jumper status : keep it master if no other device connect to the same cable
4) change the port if above 1-3 steps not work
5) Update the BIOS if above 1-4 steps not work
6) run diagnostic on motherboard related to IO / check the south bridge works find
Cheers!
Esta resposta foi útil?
Pontuação 3
Comentários:
yes the hard disk is not detected but it could be a bad hard disk
por
Adicionar a sua resposta
sara será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 453
