What screen assembly works for the Straight Talk model?
Model number is sm-s975L. What lcd digitizer assembly with frame will fit this phone?
Esta é uma boa pergunta?
If you are going to be using a display assembly that is not already adhered to a midframe, then it does not matter as these display assemblies (when off the frame) are not carrier specific. You can get any display assembly and install it without issues.
Esta resposta foi útil?
Does that mean that any s4 display assembly will work then??? Can you clarify?
Yes, any display assembly will work if it is *OFF THE FRAME*. Take heed, those last words are important. I must go now, for there are other worlds than these.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,071
Anyone? I feel someone out there has to know this.
por Austin Harris
I search the Internet and ended up here. I assume it is the same at the att model, but dont know. Can anyone confirm
por kevin
any answer to which model is compatible with the sm-s975L?
por jlopel
Same as any GSM model
por lisadunn121766
