Ir para o conteúdo principal
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
66 Perguntas Visualizar todos
My craftsman zts 7500 mower cranks over, but will not start?
What is the matter?
Esta pergunta é pertinente?
Pontuação 3
Adicionar um comentário
3 respostas
Solução escolhida
It could be many things. First I would check to see if it is getting fuel, then check the spark plug for carbon and gap then the charge going to the spark plug.
Esta resposta foi útil?
Pontuação 6
1 dos comentários:
mine did the same thing and i changed the plugs and it started right up. from stretch.
por
There is a fuel lock (electrical cylinoid) at the bottom of the carburator that could be stuck. I had this problema and fixed it by taking it off and cleaning it. Started right up afterwards.
Pontuação 4
On mine both sparkplug lost compression. That means a total loss of the engine .and it wood run about 8 too 1 thousand too fix it.
Pontuação 0
Adicionar a sua resposta
James será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 30
Duração total: 5,111
