Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Where is located the screen backlight fuse?
After a liquid spill, I've cleaned the motherboard and connexions. Everything worked fine for some time but the screen started to blink and went dark a few times until it got dark permanently.
Anyone can point me where the screen backlight fuse is located in the 13" retina mid 2014 model?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
Roy Lopez, that would be F7700 which is a 3 A 32 V fuse in a 0603 package. This "screen started to blink and went dark a few times until it got dark permanently." does not sound like the fuse. You do want to check a bit more. Of course, check the fuse first.
Esta resposta foi útil?
Pontuação 6
Pin 1 of LCD connector is probably &&^&@@.
Pontuação 0
Adicionar a sua resposta
Roy Lopez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 5,188
