How to fix recharge plug in?
Cannot recharge tablet because cord doesn't stay in on tablet. How can I fix this as the area seems loose.
Esta é uma boa pergunta?
It depends on the extent of the damage to the charge port. You may be able to squeeze the metal surrounding it back together with a pair of pliers if the port is otherwise undamaged. This would require you to remove the back casing.If the port is damaged it may need to be replaced.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 172
