I did the Replacement, now it dies immediately if off the charger
I did the Replacement, now it dies immediately if not on the charger. whats going on?
Esta é uma boa pergunta?
sk8rmonkki, what replacement did you do? The battery? Change it back to your old battery, if it stays on then you know you have a bad/discharged battery. Replace it with another one.
Esta resposta foi útil?
Shorting a battery can cause irreversible damage to the cells.
Also check for a voltage directly from the battery pack, if there isn't one then it could have become so discharged that the safety circuit has cut in. A short manual charge of the cell itself might revive it.
Working with batteries can be dangerous, be extremely cautious!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 46
