Ir para o conteúdo principal
The Envizen V100M Tablet, is a tablet PC made by Envizen Digital, a brand under Diamondking Inc. This company makes several tablets, all of which run an Android operating system.
12 Perguntas Visualizar todos
What should I do when the screen on my tablet freezes up?
When using an application, browsing through my photo library, or just normal use the screen on my tablet sometimes freezes up. I am not sure what to do when this happens as I usually just wait until the battery dies. Is there any other way I can fix this issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Does it allow you to turn it off?
Esta resposta foi útil?
Pontuação 0
Hi Josh,
If you are able to turn off the device, you could then turn the tablet back on hopefully resolving the problem, if not you could try to reset the tablet to fix the problem. For a more detailed guide on how to find out the problem see the troubleshooting guide.
Hope this helps,
Nick
Pontuação 0
I cannot put my PIN number in Everytime I try it do not see work I do not have one. So Everytime I put it in it say wrong PIN number so I cannot get in I need help or I'm going to return it
Pontuação 0
1 comentário:
Can I get some help
por
Trying to reset tablet because I forgot pattern.Its now stuck on Fastboot. Won't turn off, or move to Recovery mode.
Pontuação 0
Adicionar a sua resposta
Josh B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 717
