Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Pergunta encerrada
iPhone 5c: Replaced lightning port and battery but still won't charge?!
My daughter did a number on her iPhone 5c and I replaced the lightning port assembly, the loudspeaker assembly and the battery. Now the battery won't charge. When I plug the cable in I get the tone and the charging icon but the battery level never goes up.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Did you try to see if it makes a difference if you re-install the old battery?
por
Adicionar um comentário
2 respostas
This might be a dumb question, but have you tried a different cable?
Esta resposta foi útil?
Pontuação 0
1 comentário:
I tried 3 different cables, two different AC adapters and plugging it into the wall and the computer (3 different USB ports). No dice.
por
What exactly happened to the iPhone while in your daughter's possession? You may possibly be experiencing a failure in the logic board "power management ic", assuming your replacement battery-cable-connector wasn't somehow defective. It is generally an uncommon occurrence (and an expensive fix, unfortunately), but some experts think cheap, "fake" Apple chargers/cables are to blame for the bulk of these failures. Please check out this article to see if it sounds like your problem: https://www.mendmyi.com/blog/2014/06/has...
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 236
