I bought my SM-J100VPP on Ebay $10 … I bypassed Samsung FRP Login using ADB
adb devices adb shell pm uninstall -k --user 0 com.sec.android.app.setupwizard
( I went into Maint Mode Vol Down Power Hold ) 10 seconds… and added USB debugging Mode
then the phone boot into normal mode… and I ran the adb commands from normal mode…
( I usually think of adb as sideload from download mode ) ( So just another tip ) …
When it boot into normal mode… I had to authorize ( check mark ) allow USB debugging …
Using GSM Ultra Mobile Service Now… Setup APN setting as usual.
Phone is still FRP Locked In Bios… Can’t add Samsung Account ( Just those two things )
Hangouts Dialer works around the Default Dialer that did not recognize the Sim Card.
I use the Easy Mode as My Launcher … cause I like the big Icons… I installed Nova Launcher as a backup
to easily set the settings for the Default Launcher. I used an app called App Inspector with ADB
to get the addresses of apps that I don’t want installed. pm uninstall is only removing apps for the user…
If I was to factory reset… the Phone would be FRP Samsung Login as the Default Launcher again …
Can’t Root Phone… Can’t add Samsung account from settings… But I can install the Samsung Account Plus.apk
Being the phone is still locked I can’t turn it into a brick… lol But now it’s 100% for Network & SMS
and I can use WiFi if I want as well… All the Apps work… Very Little work to get things back to the way I like it… even if I should Factory Reset… Also good to know…. Google Play if Downloads pending… remove the updates
then downloads will go through… instead of pending.. That’s just a tip. I bought a J3 for $85 … on the T-Mobile GSM… Nice like the J1… but bigger… I think J1 is a cool size…
74 comentários
i have the same problem how can i get help
por bobby samuel mukasa
Same I don't know what to do.
por diegoadustin
I believe this helps
por JACK
can someone please help me asap
por Aliana Aguirre
Help pllz I have this problem in my Samsung A5
por nuswe8
Exibir mais 69 comentários
