How can I get the circle pad to move smoothly again?
As I try to move the circle pad around it seems sticky and jumps around. I am wondering if there is any way to get it moving smoothly again.
Esta é uma boa pergunta?
Debris may be obstructing the circle pad or a sticky substance may have been spilled on it. See the circle pad replacement guide to remove the case and check for discrepancies. If it looks okay, and restarting the console doesn't fix the problem, you may need to replace the circle pad.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,243
