The battery of my Gyro-X isn't lasting
I think the battery on my helicopter is nearing the end of its life. What should I do to fix this problem?
Esta pergunta é pertinente?
The Propel Gyro-X is a RC helicopter equipped with dual rotors and a built in gyro stabilizer. It was manufactured by Propel in the year 2014. Possible model colors are red and green plastic covers, with a black body.
Unfortunatly, it looks like this modal of RC Copter is not easily replaceable. From the manufacturers service manual (Gyropter-2013.pdf - Page 8) it says:
RECHARGEABLE BATTERY:
This helicopter uses an internal Li-Poly rechargeable battery and is not replaceable. If battery no longer stays charged, dispose of battery properly according to local disposal requirements.
That being said, if you can find a new battery somewhere (I did a quick search and there wasn't a source immediately obvious), you can probably replace the battery if you have some skills with a solder iron.
But it doesn't look like there's a nice solution to this problem.
Reputação: 1
if you take the canopy off you will see the battery.
if you handy with a soldering iron you could cut the wires and solder them to a new battery
check the dimensions of where you want the battery to fit.
I am replacing a battery on a propel gyropter is is a 1s(3.7v) approx 160mah. you could go more or less mah without a problem to get the fit right.
if I cannot find one that will fit or it is too expensive I might bet a longer one and modify the canopy.
check hobbyking or ebay
If your battery is not holding a charge, it will need to be replaced. You can find more information about this and other issues on the troubleshooting page.
Comentários:
There is nothing in the guide or on the web about how to replace what ever battery is in this thing.
por mayer
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 252
