Ir para o conteúdo principal
A linha de laptops MacBook Pro da Apple foi concebida para usuários avançados e profissionais. Atualmente, a linha MacBook Pro inclui as variantes de 13, 14, 15, 16 e 17 polegadas, com revisões maiores definidas pelos designs Pré-monobloco (original), monobloco, tela Retina, Touch Bar e SOC (system-on-a-chip).
20011 Perguntas Visualizar todos
Backlight doesn't come on after a fall.
My 10yr old dropped my Mac and now the screen is not lighting up. When I put an external light to the screen I can see the operating system faintly and I can navigate - barely.
At the moment I have my laptop hooked up to a DVI cord to another monitor and it is working fine.
BUT....It would be lovely to have my laptop back to its normal state.
My guess is that the backlight has stopped working and maybe something has come dislodged on impact. So.....if this is the case, how easy or hard would it be for me to fix it? Can I fix it if I have upgraded the ram in the same laptop or is it more complex?
I await your answer in anticipation!
V
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Before we can point you towards a guide on how to do the repairs, could you please use this link to find out what type of MacBook you have? When you know, come back and edit this question to include which specific type it is (we have guides available for 11 different types of MacBooks!). Then we can point you in the right direction. :)
por
What was the verdict? The exact same thing happened to my Macbook Pro, model 1226. Same thing. I am also wondering if this is something that is repairable.
Would you mind letting me know if you were able to fix it?
Thanks much. I'll stay tuned.
por
Adicionar um comentário
1 resposta
Solução escolhida
First step is to connect to an external monitor and check the GPU integrity. You've done it and you can now concentrate on a display lightning issue. I would check these connections:
- inverter cable to logic board
- inverter cable to inverter board
- LCD CCF lamp cable to inverter board
The procedure is to replace the inverter cable first since the part is pretty cheap, then the inverter board and finally the LCD panel (CCF lamp could be broken).
If the unit was dropped there's also the possibility of a inverter shorted cable in the hinge that damaged the inverter circuitry on the logic board. A skilled tech could check the voltage at the logic board inverter socket ouput. If there's voltage there the logic board is OK and the problem is display related.
Esta resposta foi útil?
Pontuação 5
4 comentários:
Excellent answer. + Ralph
por
I am not voting either way on this. At the time this question was presented there were 17 different models of the MacBook Pro. 11 of those models incorporated a LED backlight and do not have an inverter. This answer is only good for the following models: A1150, A1211, A1151, A1212, A1229 and A1261.
por
Adicionar a sua resposta
Veronique será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 4,542
