Ir para o conteúdo principal
The Kodak Easyshare Z981 features a 3.0 inch bright LCD screen and 26x optical zoom with a 26mm wide-angle lens. The 14 megapixel resolution makes for vivid prints up to 30x40 inches.
15 Perguntas Visualizar todos
Why won't my camera take any clear pictures?
Every time I take a picture with my Kodak Easyshare Z981 it comes out blurry and hard to see.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
Common problems that can cause this issue are:
  • If your exposure and focus aren't set properly. In order to set these on the Kodak Easyshare Z981, press the shutter button halfway. When the framing mark turns green, press the shutter button completely down to take the picture.
  • Make sure that your lens is clean and free of dust and fingerprints
  • Check what mode your camera is in - if it is in macro mode, this can be the cause of blurry pictures.
  • When taking photos, make sure your camera is steady. To do this, place it on a flat, unmoving surface or use a tripod.
  • In your camera's settings, set the picture size to be larger.
  • If you are manually setting your ISO speed, a high ISO setting may be the cause of grainy pictures.
I hope that this helps solve the issue you're having!
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Matthew Myers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 63
Duração total: 6,327
