Ir para o conteúdo principal
The Kodak Easyshare Z981 features a 3.0 inch bright LCD screen and 26x optical zoom with a 26mm wide-angle lens. The 14 megapixel resolution makes for vivid prints up to 30x40 inches.
15 Perguntas Visualizar todos
Why won't my camera turn on?
I was using my camera the other day and suddenly it shut off and would not turn on again. I'm not sure what's wrong with it.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Ensure that the four AA batteries are properly inserted in the camera with the positive and negative ends of the batteries pointing in the right directions. Additionally, make sure the battery cover is completely closed and shut properly. If still no success, try removing and reinserting the batteries, or replace the batteries entirely if your Kodak Easyshare Z981 still doesn't turn on. Lastly, if you are using rechargeable batteries with your camera, make sure they are fully charged and ready for use. Additional help is available on the Kodak Easyshare Z981 Troubleshooting Guide located here: Kodak Easyshare Z981 Troubleshooting
Esta resposta foi útil?
Pontuação 0
3 comentários:
when I push on button, code light just flashes
por
same here. any solution
por
por
Adicionar a sua resposta
Olivia Boyna será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 4,665
