Ir para o conteúdo principal
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Perguntas Visualizar todos
DC IN Voltage Fails TechToolPro Diagnostic
I have a MacBook Air that sometimes doesn't startup at all.
So I ran the TechTool Pro 8 diagnostic on it and it has a sensor failure: DC In failed at 16.96v.
Does anyone know if there is a way I can fix this other than a new motherboard?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
You may be using the wrong power supply. The Air uses a 45 watt power supply at 14.5 volts. All the other laptop products use a 16.5 volt supply. So if you hook up a MacBook Pro power supply you're going to see 16.5V to 17V on the DC-in rail (depending on the accuracy of the sensor).
por
Adicionar um comentário
3 respostas
Solução escolhida
The Mag-Safe is built into the I/O board. There does not seem to be a repair guide for this machine but there is one for the A1466 2012. Take a look: MacBook Air 13" Mid 2012 I/O Board Replacement
Esta resposta foi útil?
Pontuação 2
I just replaced the part for a brand new one from IFIXIT and it didn't fix the problem.
I'm still get the DC-in Rail 0 Failed at 16.67 V.
Anybody else managed to fix it?
thx
Pontuação 0
1 comentário:
You'll need to trace the voltage from the I/O board back to the main board as you have a disconnect along the pathway.
por
I had the same issue and I fixed it by using the right charger. No more errors now!
Pontuação 0
5 comentários:
Right…charger??
por
Are you saying that you can use a Thunderbolt 1 port to charge a MacBook Air??
por
Use a genuine Apple 45W charger. Fake chargers do not have a stable voltage and can cause this issue.
por
Oh, the *correct* charger! I thought he was charging through the right side—i.e. the Thunderbolt port.
por
He was using the wrong power supply. The Air uses a 45 watt power supply at 14.5 volts. All the other laptop products use a 16.5 volt supply. So if you hook up a MacBook Pro power supply you're going to see 16.5V to 17V on the DC-in rail (depending on the accuracy of the sensor).
por
Adicionar a sua resposta
randy4 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 3,264
