Phone will not power on
I disconnected my iPhone 6 plus from the charger and as soon as it was disconnected the phone turned completely off and now won't power back on.
Esta é uma boa pergunta?
Fist check to make sure the phone charged when you had it connected and charging. It may just be that it never charged.
If it's charging, try a hard reset, press and Hold down the home button, & the power button at the same time, until you see the phone turn off, and come back on and you see a black screen with a white Apple logo. Then let off both buttons. It will go back to normal if that worked.
If not, connect to iTunes via PC using A USB cable and try doing a Restore and back up
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 385
