Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
My phone keeps clicking on things that I'm not even clicking on?
Whenever I unlock my phone, it goes crazy. It starts having a spazz attack and clicks on random stuff by itself. For example, I will go to my messages to try to text someone and it will just start clicking on letters and buttons out of no wheres, causing me take 20 minutes just to send a simple message. I have no control over it and it is really annoying. This started happening after I went in the store to get my cracked screen replaced.
Esta é uma boa pergunta?
Pontuação 181
107 comentários
Yeah but mine is perfectly fine and it started doing it and right before this I was in the lock screen and it started pressing random numbers as soon as o got to 2 numbers and then i turned it off and the assistive touch was the assistive touch was on so I did a screenshot and it fixed it then while I was writing this it messed up again ,my phone is fine except when my phone screen wh..ohhhh my phone screen keeps blacking out any fixes?
por
This happened to me when I wet my phone, I was cleaning it with water and it got wet and started clicking random things I wasn't I honestly don't knkw how to fix it, the only way if stops is I shut it off for a while , but it will eventually come back within 10 minutes
por
this mistake happens when we are in text writing mode and then when switched to main page (home) random touchs stopped. when a game is running everything is OK. result is if we can change the android sensibility for touch in writing sms we hope to fix it. is there any solution for change android variable by programming or by rooting my phone?
por
Guys, i have the same issue. But ifix it by simply cleaning my touchscreen. I think it all about oiliness of hand the reason of malfunctioning. Other wise it's a virus. Other option is to lower your pointer speed in(Setting, Language and input, Pointer Speed. I hope this could help you. God bless you!
por
my phone again has a similar problem except from that its presses randomly and the only way i have found to try and fix it slightly is to bend my phone slightly in each direction, this makes it work and i have been thinking the whole time that it was because my phone was bent, but this extra bending of my phone is causing the screen to pry itself out of the case slightly and i have no idea about what i should do about it or not...
por
Exibir mais 102 comentários
Adicionar um comentário
3 respostas
Solução escolhida
You have a bad aftermarket screen. Take it back to the place that repaired it.
Esta resposta foi útil?
Pontuação 38
67 comentários:
Sometimes this can be solved by unplugging the battery and eplugging the front display connectors and holding power button for 5 seconds then plugging the battery in and putting it bsck together. Though I'd only recommend this if you've repaired iPhone 5 before.
And he's probably talking to both of you. You both probably have bad aftermarket screens.
Edit: This thread is so old lol.
por
This happens to my phone too. I cracked my screen and got it replaced in July, and my phone just started spazzing out a few days ago
por
My problem is same but I have huawei honor 3c
por
Can someone please help me... my phone is going out of control only when the data connection is turned on. It's totally fine when I'm using Wi-Fi... is this a common issue? Should I check for viruses?
por
This happens to me and I have never had my screen replaced.
por
Exibir mais 62 comentários
Pergunta mais útil
All you need to do it disconnect the charger, trust me you need a new charger well only if your phone is going crazy while charging it then just get a new charger and if it's not happening while you're charging it then the phone has a problem
Pontuação 49
32 comentários:
It worked! THANKS! :-)
por
This seemed to happen to me right after I charged my phone but it wasn't fully plugged in to the socket right. Now it keeps pressing randomly even when I'm not charging. Any tips?
por
This worked perfect. When I reconnected the old phone charger the problem returned.
por
Same goes for me. This problem happened when I connect my phone to my charger. So, if the charger was the culprit, what should I do with it? Throw it? Or can I use the charger for other devices, such as iPhone or iPad or stuff? Thanks
por
I have the Same problem with my iPhone 6 and I used to have it with my ipad mini which was broken to oblivion and was clicking on random things and then I got it fixed and the problem went away but with my iPhone 6 the screen isn't cracked or anything and just randomly starts to type things and the screen can be so unresponsive.
por
Exibir mais 27 comentários
Ok I’m trying this again all you need to do to fix this clicking problem is to go to settings on your home page, scroll down to Accessibility then scroll from there to “ General” then to Guided Access this needs to be shut off along with the Accessibility shortcut- shut both off and it should fix the problem- it’s suppose to help disabled people but I can’t believe it does!! Ok hope that helps- my phone never did that clicking thing again so.
Pontuação 1
1 comentário:
This didn’t work for me as both of them were already off
por
Adicionar a sua resposta
Jami Bush será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 23
Últimos 7 dias: 189
Últimos 30 dias: 725
Duração total: 1,625,323
