Ir para o conteúdo principal
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
83 Perguntas Visualizar todos
Screen flickers for half a second then goes blank.
I just found a LED Cinema Display during spring cleaning that is not entirely working. The audio, charger, and usb all work on the display. The screen is detected by my 2011 13 inch MBP. About 40% of the time when I plug the thunderbolt cord into my laptop the screen will flicker for a half a second and then go completely black. I used my flashlight to look at it and I do see my computer's desktop on the display. From what I can see the backlight isn't completely broken, I figure it is either a problem with the thunderbolt connection or the logic board.
Thanks.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Hey, did you ever get this fixed? I have the same exact issue.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like you have a cold solder joint on the logic board on the backlight WLED driver or the driver it's self is blown.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks Mayer! Good vid on cold solder joints.
por
Adicionar a sua resposta
crennie123 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 2,947
