Ir para o conteúdo principal
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
How can I troubleshoot a MacBook that won't switch on?
I got a MacBook off ebay, with a known overheating problem. I disassembled it (using guides here!) and cleaned it out. Inside there were a few small sticky patches that might've been a liquid spill, as well as lots of hair and dust!
It was working before (though the fan made nasty grinding noises) but since taking it apart it's now completely dead!
When pressing the power button, there is no screen image and no chime. Not even the fan kicks into life.
The battery is showing fully charged, and when the magsafe power cord is plugged in the light comes on green after a second.
What might I have done wrong? How can I go about troubleshooting this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Unplug the power adapter from the electrical outlet and from the MacBook. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the power adapter LEDs should light up green or amber. Press the control key, the command key, and the power button simultaneously and hold for three seconds to try to restart the computer.
Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the battery and then holding down the power button for five seconds. If none of this works then the first thing to check is the keyboard to logic booard connection as the machine may not be getting a signal to turn on.
Esta resposta foi útil?
Pontuação 3
1 comentário:
+ Ralph
por
Adicionar a sua resposta
Aled L será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 2,613
