How to best re-atach the cable?
I did remove the cable on my Kinect by pulling it out using some force.
Now I want to plug it in again. Has anyone any tips on how to do that properly?
Pictures on the rotation of the cable, the process and a few tricks would be very much apreciated.
I could also use a picture of how the port is supposed to look when it is not damaged to compare it to.
This might be helpful to people in the exact situation as I am- be it because of curiousity or because the cable needs to be swapped out.
Update: Just to clarify: Nothing is definitely broken- just need help figuring out how to plug the cable in again without killing the port.
Esta é uma boa pergunta?
goldsteal, it will help if you attach images of your damage and your cable. Use this guide Adicionar imagens a uma pergunta já existente for that
por oldturkey03
Simply plugging in the cable is not possible due to the rubber preventing it. Do I need to open the Kinect? Is there a trick?
por goldsteal
