Ir para o conteúdo principal
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
I can't charge my iPad
When I connect the iPad to the power adapter it appears the green battery with the lightning mark but the i pad won't charge
I tried the restor
I tried another power adapter
I tried another cable
I tried hold the two buttons
But the issue wasn't solved
Esta é uma boa pergunta?
Pontuação 3
1 comentário
does the cable go in far enough inside the dock?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Firstly,iPad Air Battery is particularly sensitive to temperature, There are a lot of friends would like to protect it with the Case. But when the weather is hot in the summer, may it will lead to dissipating heat is not good and it failure. So please take it out.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Sohaib Khelfi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 1,278
