Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1624 Perguntas Visualizar todos
SSD boots over USB, doesn't boot connected internally.
Hi,
I tried replacing my internal HDD by an SSD (crucial m550 - 256Gb) on my Mac with the latest OS running.
I made a clone with carbon copy cloner from the original HDD to the new SSD (ca. 130Gb).
The SSD boots perfectly when connected over USB, but is not found when connected internally.
However, when I updated de SSD's firmware, I booted from a CD with the SSD connected internally and it was found without a problem.
When I boot with the SSD internally connected I just end up with a grey screen and a fold+questionmark icon.
  • i updated firmware on ssd
  • i checked if firmware on mac was latest version
  • I cloned the disk again and checked there was a safety partition created
  • a clean install from scratch is not an option: i've got software from my work that I can't get a new regkey for.
…I really have no clue what to do, but I can't get my SSD working. Any ideas? Thank in advance!
Esta é uma boa pergunta?
Pontuação 1
2 comentários
The support of Crucial mailed me I should partition the SSD correctly to install OSX. Of course that's not helpful, since I can boot OSX through USB already.
(Correct partitionings is the GUID partition table --> That seems to be taken care of by carbon copy cloner.. You can check it in the Disk Utility)
por
No one here replied, but luckily the support of Bombich software (makers of Carbon Copy Cloner) provided me with this solution:
We have received numerous reports of hardware compatibility issues when installing a cloned hard drive from an external enclosure into various Macs.
1. Shut down your Mac
2. Install the new disk inside your Mac and put the original disk in your external enclosure
3. Boot your Mac from the original startup disk in the external enclosure -- hold down the Option key while booting your Mac to get to the startup disk selector screen
4. Re-initialize the new disk (in the partition tab -- reapply the "1 partition" scheme to the disk)
5. Clone your original source volume to the new disk
6. Set the startup disk to the new disk in the Startup Disk preference pane and restart your Mac
Note: Step 4 is very important -- be sure to apply a new partition scheme to the disk, don't just erase the volume. This video indicates how to repartition the disk: http://www.screenr.com/SQM
por
Adicionar um comentário
3 respostas
Solução escolhida
This workaround seems to work for most users:
Esta resposta foi útil?
Pontuação 1
7 comentários:
Thank you for this. Worked for me using a Samsung 850 EVO 250GB in my “Late 2006” black Macbook running OS X Lion. Would boot via USB but not internally. Now all is good.
January 2018
por
How do i reinitialize the disk from there? Im not seeing a thing
por
Might try step 6 first before wiping disk, this did the trick for me
por
I had this issue too, installing a 1GB Crucial SSD into a late-2013 iMac. As DLX suggested, just setting the Startup Disk to the new drive worked.
por
Hi
I had same issue when trying to upgrade macbook air late 2008 (A1278) to 250 GB crucial SSD from 160GB HDD (Toshiba).
This solution worked fine for me, thanks a lot for providing this solution.
Also I will ask crucial to update their documentation https://eu.crucial.com/eur/en/mac-ssd-in....
Br Peter
Ps: One minor comment: In step 3 above I had to select SSD recovery disk to load disk utility, since original HD was not shown as boot disk. Original HD was shown fine when disk utility came up.
por
Exibir mais 2 comentários
use your phone camera to try and take a picture of the inside of the SSD connector for me please.
Pontuação 0
2 comentários:
This is not an answer, it is a comment.
por
There was not nothing wrong with the connector. It now is working fine as you can read in my comment.
por
Please Help!
I got a new evo 860 and I installed it. I had a time machine backup in an external HD. I have now a copy of the back up in the SSD but it won’t start up. The only time it worked was when I left the external drive connected and turned it on, it used the external to start up. I tried switching the startup but it didn’t recognize the SSD.
I tried following the steps you mention before but the repartition video didn’t load.
I would really appreciate the extra advice on this!!
Pontuação 0
2 comentários:
I couldnt get mine to work either is it the cable itself?
por
I am having the same issue. Did you solve your issue? Would love some input.
por
Adicionar a sua resposta
Saber será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 34
Duração total: 18,824
