Ir para o conteúdo principal
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 Perguntas Visualizar todos
Radio Wont Turn On
Hey everyone, a few days ago I plugged in my Phone charger into my van and it started charging my phone for about 5 seconds. After that it started smoking and now the radio will not turn on. I can not play Cd's or cassette tapes either. It wont even let me use an auxiliary cord to connect to my phone for music. I'm assuming its a blown fuse but I am not sure about that. I found the fuse box in the engine but Ive looked on the internet and every website says that that fuse box doesn't have anything to do with the electronics on the inside of the vehicle but they don't say were the other fuse box would be. I have researched more and websites say there is another one but they don't say where. if you guys no where it is could you please let me know so i can get my radio fixed.
Esta é uma boa pergunta?
Pontuação 9
7 comentários
what year is your van ?
por
2001 Dodge caravan
por
My radio is not turn in and the dude is good, I hace a 2005 Caravan
por
Its not a fuse, it is a accessory relay which is located in the fuse box up front that powers the 12 volt outlets and the radio..
por
I have a 2007 Dodge Grand caravan. The radio , everything is working . All the speakers just stopped working. I'd check the fuses , but where are they !?!?!?
por
Exibir mais 2 comentários
Adicionar um comentário
7 respostas
Solução escolhida
I had the same problem twice and I fixed myself, you are right is a blown fuse and is in the fuse box that is located in the engine compartment, you have to look for a yellow 20A fuse.stand next to the driver side front tire, with the head light to your left and driver door to your right,is 3 yellow fuses near to the battery check the one on the left that is the one for your radio. On the fuse box lid is marked as RDO/IPIGN. I drive a 02 grand caravan ES, I hope this help solve your problem, driving without music is not fun at all.
Esta resposta foi útil?
Pontuação 27
22 comentários:
that might help i half to drive with no music
por
I can always count on this site to help me thanks
por
Right on the nose! My radio had stoped working 2 days ago while I was plugin my phone-jack. Found this fix up and stoped, opened the hood. Opened the fuse box and after looking around a little bit found the fuse, took it out and there it was! Shorted. Went to my local AutoZone and bought the fuse (pack of 5) and changed the offending part. And presto! I have radio again. Grand Caravan 2005. Fixed. Thanks!!!
por
Thank you! You are a genius!!!
por
What about a 2014 Dodge Grand Caravan sxt?
por
Exibir mais 17 comentários
I have an 02 town and country and I changed the blower motor fan and resister and now it works fine but if I turn on the radio it blows a fuse can anyone help
Pontuação 1
I HAVE SOLVED THE SHORTING OUT PROBLEM OF THE RADIO SHORTING OUT, FLASHING, RESETTING, OR JUST PLAIN NOT WORKING!!! It is in the radio, behind the buttons. After six months of listening fools tell me to connect and disconnect, change fuses, etc, and pulling my hair, i finally removed the radio. using a star set of drivers i removed the front panel of the radio, and then the green board on the back of that panel, looking for dirt or bad connections. i found two flat, square, gold contact points on the green panel. there were tow very thin metal contacts on the button board that corresponded to these contact points. i noticed the metal was bent very far down, so i very gently placed a tiny screwdriver behind the contacts and gently bent them forward, where they would make a better contact with the little squares. i screwed the radio back together, re-installed it, and BAM. worked like a champ. lights, buttons, switches, the works. i'm going to go take a ride now and listen to my radio -- on ALL the stations.
Pontuação 0
2 comentários:
I am having same problem with my radio in my 2002 Dodge Grand Caravan sport- radio suddenly switches station then resets to 12:00. Now not working at all! I checked fuses- all OK. I took apart the center area to pull radio out, and checked wires leading into. but I did not take apart actual radio as there are all these warning stickers on there about invisible laser beam radiation-- is that the compartment you opened? We also have a DVD player that has not worked for 2 years - the dealership said it would be like $500 just to look at it (on our 14 year old van!)
por
update -- my fix was temporary. best advice -- get a new radio. i got one on craigslist for $20 and it works perfectly
por
Thank you was absolutely correct plugged in phone charger and radio went out but clock time still worked
Pontuação 0
J ai un Chrysler town&country 2014 et j aimerais sortir ma musique du radio Sirius pour le mettre sur mon pc afin de la conservé,comment faire merci clay_1950@hotmail.com
À
Pontuação 0
I have a 2004 Chylser town and country van my radio turns on and switches channels but there's no sound. Could anyone tell me what the problem could be I hate driving without music
Pontuação 0
I.have a 2005 3.3 caravan an when I cut the car off heat windshield wipers an radio come on.but when cars on nothing comes on.Help me please it's getting cold out what would that be???
Pontuação 0
1 comentário:
2014 Chrysler Town & Country: had the starter replaced. DVD disc player worked fine before. VES rear screen is blank. I have audio. Can someone walk me through steps to reconnect rear VES? REAR screen is #2 or #1? Any help would be appreciated.
por
Adicionar a sua resposta
Dante será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 37
Últimos 30 dias: 167
Duração total: 80,068
