Why Won't my ps4 turn on
My Ps4 Was Infested with roaches and when I try to turn it on it wont turn on
Esta é uma boa pergunta?
The most likely cause of your problem is a faulty power supply. Roaches LOVE living in the power supply because it gets so warm. They walk around inside the power supply and eventually touch two points that shouldn't be touched and ZAP! Sometimes they start making "trails" inside the power supply of feces. These trails can sometimes cause short circuits because the power will sometimes go through the trails instead of the circuit trace that it should be going through.
It could be other problems as well, but the power supply is by far the most likely cause of your problem.
I hope this helps!
Esta resposta foi útil?
Should I Take It Apart and Clean the trail or juss buy an new power supply and Apply it ?
You'll be better off just buying a new controller. There is most likely some components that have burned out too so you would have to replace those as well.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 778
