Ir para o conteúdo principal
The fourth Google Nexus smartphone, released November 13, 2012.
75 Perguntas Visualizar todos
Pergunta encerrada
Nexus 4 Touch Panel Replacement Issues
Hi,
I recently dropped my Nexus 4 and the front glass of my phone is broken. The actual display doesn't show any signs of damage and it's only the touchpanel (digitizer?) that's damaged. After looking through a lot of videos online, I realized it is possible to replace only the touchpanel while using the existing display itself.
So I ordered a touchpanel online from Amazon and received it a couple of days back. I have disassembled the phone successfully and even carefully removed the broken touchpanel from the display. The dissplay boots up fine, but the moment I connect the new touch panel, the screen goes completely white. I have rechecked all the connections and everything seems ok to me, but still unable to figure where the problem lies.
Can someone please tell me if I am doing something wrong or the new touchpanel I ordered is defective? Any troubleshooting techniques to identify where the problem lies?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It seems you have broken the LCD screen by heavy pressure or overheat when replace the touch panel.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 118
