Makes 1st cup then will not pull in water from reservoir
My Keurig atuo powers on in the morning. The first cup brews as normal. Water is pulled in from the reservoir and it dispenses a full cup. On the second cup, it makes the motor sounds like its pulling water from the reservoir, but no water is pulled in. Then the blue lights blink as if the reservoir is low, but in fact it's only missing the water from the first brew. Next day it will do the same thing. Cannot get 2 cups out of it when it's heated up.
Esta é uma boa pergunta?
1 comentário
It seems to only happen when the maker has been on awhile. If I turn it on later in the day and make a cup right away, it will make more as usual. If it's been on awhile it's like there's a vapor lock and won't make the second.
por Brian
