Low wifi signal, also drops off
Hi, I just fitted a new housing and power button flex cable then put it all back together nicely, but now my wifi doesn't find any networks and when it does it's always really low and drops off. Does anyone have any idea on what the problem may be? I'm going to open it up again to see if anything is loose, if anyone else has some suggestions, thanks
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
Being that you just replaced the housing, you might have damaged the wifi antenna that sits above the battery and is connected to the logic board. I would recommend replacing the antenna since it only costs $19.95 from ifixit (iPhone 5 Wi-Fi Antenna)
Also, here is the repair guide for your convenience: iPhone 5 Wi-Fi Antenna Replacement
Hope everything works out and please keep us updated as to your results.
iPhone 5 Wi-Fi Antenna Imagem
Produto
$19,99
Esta resposta foi útil?
Pontuação 1
Remove the board, follow the iPhone 5 Wi-Fi antenna replacement guide to see where the antenna connects on the top but back side of the board (no pun intended).
Either you
1/ Forgot to transfer that antenna, or
2/ Forgot to connect it (most common) to the board, or
3/ Torn it in which case you need to replace it, or
4/ Broke the antenna connector on the board, or
5/ Damaged other tiny components on the board relating to Wi-Fi reception.
Usually it's #2. Good luck.
Pontuação 1
Their could be multiple issues with it. u could have damaged the WIFI/Bluetooth Antena or its not seated properly! does it greys out on u?
Pontuação 0
Adicionar a sua resposta
William será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 169
