Ir para o conteúdo principal
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Perguntas Visualizar todos
Ipad 4 doesn't charge
Hello, I installed a new battery and a new lightning port. My iPad turn on, but the battery doesn't charge, when I plugged it to the power outlet, the iPad only indicates "battery charged" when It had only 65% of charge. Only It charges, when my iPad is turn off, but when It turn on, it didn't charge. Now, my iPad doesn't turn on. I changed the battery two times. Also, I re-installed the old lightning port.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It is very likely that you have damaged the U2 charging logic ic chip, probably happened because you created a short on the main board while trying to replace the battery. It is repairable but it requires a board level repair.
Esta resposta foi útil?
Pontuação 1
1 comentário:
do you happen to have a picture of the chip that needs to be replaced
por
Adicionar a sua resposta
Michael Beltran será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 481
