2009 Ford Escape windshield washer not spraying?
My 2009 Ford Escape windshield washer front and back stopped working at the same time a few months ago. I haven't had a chance to look at it until last night. The reservoir is filled to the max line. There hasn't been any leakage. I tested the pumps by having the hood open, windows down, and ran the motors. I know they work because they are on the same circuit as the wipers. The wipers work, but no fluid in front or back come out? Would this be a clogged pump, reservoir dirty, or clogged lines? Thanks.
Esta é uma boa pergunta?
Brian, did you find out what was causing this? I have the exact same problem. David
por David
Brian, did you get a resolution to your problem? I'm having the same issue. Doesn't seem right that it could be the pump, since it appears there is a separate pump for front and rear.
por davetodd5
Hey Brian,
I'm glad to hear it was a simple pump to replace.
PT
por Paul
Which pump did they replace since both front and back were not working? Or did they have to replace both??? Just curious, mine Escape is doing the same thing.
por jbirk
having the same problem went to local AAA car service, they first asked to sign for $99 diagnostic labor. Then after they checked waved the charge since the problem with no spraying in front and back was solved in a min by untangeling the line leading from the reservoir to the nozzles. Solved.
Before I went to this service I have excuded the bad fuse, since the windshield wipers (front & back were working), also that the pump is working by opening the window and the engine cover and listening whether the pum is working, i.e., producing a noise. So talking to the mehsnic I indicated that he needs to check for cloging, or else with the line, and he focused and found the cause very quick.
por vik1919
