How to make sure LCD cable doesn't become loose over time?
Hi all,
I have a ASUS ROG G550JK laptop, which has an annoying problem. The screen does flicker randomly from time to time, by I mean randomly, it flickers for a frame only, and then doesn't flicker for 5-10 mins etc. then flickers randomly for one frame again. One thing to note is this doesn't happen on an external screen, only at internal laptop display.
I have opened the laptop and reseated the LCD cable on the motherboard, then for 2-3 days it didn't flicker but then it started again, figured it become loose again, I did the same process again, and it didn't flickered for 2-3 days but now it's flickering again.
What can I do to make sure the cable doesn't become loose in time? I thought I can try to fix it with some electrical band. What are your opinions? Thank you very much for your help.
Esta é uma boa pergunta?
2 comentários
My screen is completely black, before it went that way it flickered a couple times. I have reset the connection several times but I still have not had any luck bringing it back to life. Do I have the same problem? I didnt have any of the tools that you suggested on me but I will make sure I get them if needed. Thanks for reading this I hope it can be easily fixed.
por MARCUS BIRD
My screen turned black a while ago like 2 years ago but from time to time when I put preasure sometimes in the screen hinge my laptop screen comes on so I'm wondering if it's a lcd loose cable and if I could diy it and my laptop is hp brand
por Aaron
