Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone 5s Broken resistor on logic board. Can't turn on~
Hi guys,
Since I repairing my 5s, unfortunately I broke one of the resistor of logic board.
Does anyone knows this one ?
What if I just jump with both of points, it will be problem?
After I broke it, I couldn't turn on the power
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
That is reference designator C381 which is a 0.1uF 16V 10% capacitor in a 0201 package.
por
Adicionar um comentário
2 respostas
Replace the old logic board with a new one !
Esta resposta foi útil?
Pontuação 0
C381. It is not a resistor. Shorting the pads together will short out your whole phone, so yes--will be a problem.
This component is unlikely to cause a no power problem in the 5s. Try prompting your phone to boot by plugging it into the charger.
Give us more details about your specific problem and the history of the phone and we can give you some guidance.
jessa
Pontuação 0
5 comentários:
Thanks for help!
Firstly I was trying to replace to new lcd since old lcd has glass broken.
Once when I replaced with new lcd, and turned on power, I felt that my phone shows that high temperature than before, so I reworked from disassembled whole lcd screen and reconnect with logic board without complete @%^'y with body( just connected the cable only), when I turned on the power, I saw the apple logo, but unfortunately my baby touched phone so the phone moved little bit,yes I believe the connector had been short out.. Anyway it was turned off by itself so I re-turn on the power..Then I start to seeing the apple logo with unclear spot on lcd.
Then I turned off again try to disconnect the connector which is on the picture part, I made mistake that I hit(?) or touched(?) C381 clean the connector..
After that, couldn't turn on again...
Can u help me out?
por
Sun---you need to rule out no power vs no display. Does your phone connect to iTunes (you can leave display on or off, doesn't matter. just connect battery and plug into your computer.
por
Thank u so much.
I just saw this and followed as ur comment.
And it look like working properly, however since C381 has broken, I think it will have some issue later right?
Could you give me little more advise ?
Thanks
por
probably not. most capacitors just filter electrical signals and make them look nice and pretty for the ic chips to understand. Unless the schematic says "critical" then you probably won't notice. time will tell.
por
Wow!!! Thanks a lot, again!! you saved my lovely iPhone 5s!!
have a great day!
por
Adicionar a sua resposta
Sun será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,235
