Can't hear or be heard when making phone calls.
I'm working on a 5 s which took a few knocks and needs the screen replaced. Another problem was that the user couldn't hear or be heard when making phone calls. I replaced the camera/ mic / earpiece cable as well as the earpiece and clip. That still didn't solve the problem.
Replaced the original parts , no difference. Checked the connector on the logic board and nothing obvious as far as damage goes. Other than this problem the iPhone works fine. Any thoughts on what the problem could be?
I should also mention that using hands free and earphones w/ mic also yield the same results.
Esta é uma boa pergunta?
2 comentários
Anybody? Bueller?
por Brian
so I placed the logic board inside an entirely different chassis and am still having the same issue. This tells me that its definitely the Logic Board. The only issue is that while in a phone call you cannot hear the other caller and they can't hear you. Other than that audio works fine in other apps
por Brian
