Ir para o conteúdo principal
Released September 2013 / Black, Blue, White or Pink Casing / 4GB of memory.
19 Perguntas Visualizar todos
Why won't my tablet turn on?
I try to turn on my tablet by just holding on the power button for about 3 seconds but it would not turn on. After that, I tried holding down the power button for approximately 30 seconds, but still no luck.
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
2 respostas
Your problem may be a drained battery. If your tablet won’t turn on, check to make sure the battery isn’t dead after continuous use. Plug your tablet in through its corresponding cable to either a computer or AC adapter to see if anything happens. If it still does not turn on, your battery may no longer hold a charge and must be replaced with a new battery.
Chromo Inc T2 Troubleshooting
Esta resposta foi útil?
Pontuação 0
I just used my tablet twice and now it doesn't turn on, or better yet said, it doesn't go past the adroid picture (when turning on)
Pontuação 0
Adicionar a sua resposta
Ismael DeLuna será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 2,412
