Why won't my camcorder turn on?
When I press the power button on my camera it does not power on. What am I doing wrong or is my device broken?
Esta é uma boa pergunta?
Hello Jarretti,
Make sure the camera is fully charged or charging. If you connect the device to a computer or a charger, a screen should show that it is charging. If the screen pops up, it means that the camera was fully discharged. If the screen does not pop up, you may have a dysfunctional device but do not be alarmed and upset because there might be a way to fix it!
The reasons the camera is not turning on can consist of water damage, the camera may have fallen too hard, the battery is fully discharged while the port is not accepting the cable, etc.
If you like to find the cause of the issue and consider fixing it, please take a look at the guides found on the device page where you can find step by step manuals to help narrow the causes down and help get the camera working again.
Do not give up on your device!
Christian M.
Esta resposta foi útil?
My camera is charging and i know that cause there is a orange or green light but it will not turn on what should I do
I am not having technical knowledge I need technician to fix my camera. Help me my video camera is still new.Botswana.
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 3,046
