Ir para o conteúdo principal
The Netgear WNDR3800 was released in 2011.
Why won't the Netgear WNDR3800 power button turn green?
It was working fine earlier this morning but, when I got home this afternoon the power button won't turn green or any of the parts. The power did go out while I wasn't here but everything else seems to be working fine. It will blink every so often and the power button would stay Orange. Also when I tried switching out the power switch with the Cisco switch it came on but I was not receiving any internet connection.
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
you just need to setup the router for more steps http://goo.gl/d1EhUX
por
Adicionar um comentário
1 resposta
Try resetting it o the factory settings. Usually when the led do not turn green and remains amber it means some issues. Depending on your knowledge you can troubleshoot ore fix it :)
some basic instruction HERE
OS
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Amber será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 1,083
